Hey i gotta dumb question. My truck has a weird sounding rev on top end. It runs fine untill i put it to the floor, then i rev's kinda steady, almost like my clutch is slipping, but still picks up speed and no burnt clutch smell. (south bend installed last fall) If im grabbing gears as fast as i can, going up a steap grade or coming back down it still does this. I was wondering if could be something in my injector pump. I was in there awhile ago installing the 3200 spring, but it did this before i put the spring in. Other than that i have the fuel screw and starwheel in acouple turns, and the fuel pin is pointed towards the firewall. Im not sure where to look for this problem, my clutch has never been slipped to get glazed over or anything, and again doesnt smell at after i run the truck hard, ive had my nose up to the inspection plate! Any suggestions?? Its ok to tell me im crazy!
_____________________
93' W250 cc LE, NV4500 & SBC, POD's, PDR HX-35/16, pump mods & timing, open air, 4" from factory flange to dual 5" miter cut stacks. auto meter pyro & boost.
