2nd Gen Non-Engine/Transmission Weird headlight problem
2nd Gen Non-Engine/Transmission Fuel Cap Vented or not?
2nd Gen Non-Engine/Transmission missing issue
Blue dash light stays on in either dimmer switch position. In one position the low beams are dim. In the other position, the low beams are bright. The hign beams don't come on in either position!
Any ideas?
You should be able to swap the relay out with another one in the pdc before you go buy one.
Not sure if the 96's are the same but my '01 had an underated Multifunction (dimmer) switch. The contacts melted causing the high beams to stick in the 'on' position.
My truck does the same thing since putting in sport lights.
To get them off high beam, I push in the light knob to off for a second. Viola, low beams. :D
Edit; After reading the OP better... . not exactly the same as my problem. My truck goes to high beam.
