The 370s will probably be way too much. I think the HX-35 is out of its efficiency range at, or above 35psi. Not sure what effect the 16 housing you have on there would be. Never ran a HX-35 with one.
I was pegging my 30# gauge with the #10 in stock position and bone stock turbo/ injectors. If I really want to get on it with what I have now (and still stock pos. on plate), I can hit 32# boost and 1250*pre-turbo. Even with the PDR HX-40. On your truck, I would expect 40#+ of boost and maybe excessive EGTs if you tow, depending on what you are hitting now. At minimum, you may what a hybrid HX-40/35W or a modified HX-40. Been very happy with the PDR turbo that I have on.
The 370s can add alot of fuel. I felt a bigger difference in power with the 370s than the plate alone. If I had slid the plate, it
might have about the same effect as the injectors did. I like where everything is set at right now. Don't plan to add or mess with anything power-wise. For now, that is.
The HP bug may bite again.
:-laf
With still having a stock transmission, I haven't had the nerve to hook up to a trailer yet, since the turbo or injectors went in. It pulled great before, anxious to see what it'll do now. Oo.
