Think about it, why would Cummins need the two dowel pins for an assembly done on a stand in the wide open with two parts that can only go together one way if they were just for locating? The pins are there to keep the case, which also supports a 50 pound injection pump, lined up correctly, the bolts have play.
The more I think about what the dealer did for Phil the more ticked I get. At least they covered the repair under warranty when the mileage was up. Even if the J-B Welded case holds up you are still going to have to remove the cover, pound in a new pin then contain it.
