Throttle started acting up today. Cruising low rpm, give it throttle and nothing, very, VERY minimal acceleration, almost like I barely pushed more on the throttle. No check engine light. SO. . I've been reading and need input.
BTW - I have 73k miles right now.
1. I've read that the injection pump is covered 5 years/100k mi. Is this correct?
2. Where is the APPS and what is the correct procedure to reset it?
3. I want to change the lift pump, ASAP, so what should I go with? Would a factory replacement unit also be prone to the same problems?
Thanks
Eric
Thanks
Eric
