blackram99 said:
Not so sure I believe in that theory. A friend of mine is into truck pulling big time..... he has done well ( 1st place every year in 4 different fairs ) for 3yrs. straight with his 2nd generation(2001) ..... He got a new 3rd generation (2004. 5) with the same modifications, and cant get past 5th place... . Both trucks were quad cab's and 6' boxes, same rear end ratio and everything..... only difference is his 2nd generation had the automatic and his 3rd generation is the standard 6 speed... . maybe that has something to do with it, I'm not sure..... ohh well that is just my 2cents... ...
Here, in the "professional" pulling, IF a Diesel powered rig is even light enough to get to pull, it doesn't do that well anyway. It depends on your rules in your area. Here your truck can't weigh more than 5,500 lbs (mine weighs 7,025) and there are a number of other rules. Besides that, without extreme modification, you're not going to be able to compete with the 800+ HP gasoline powered pulling trucks.
When pulling, I personally would rather have an automatic. This is one of few instances where I think an auto is superior. Some guys have sucess with shifting gears if the track surface will allow.
Pulling is all about traction, momentum, and weight. All engines make torque. It doesn't matter if you have a Ford, Chevy, or Dodge. The more HP you can make, and the more weight you can keep over the front wheels when the weight box moves forward, and the more momentum you can gain in the first 50-100' or so, the more sucessful your pull will be.
I'm going to try my hand at pulling with my Dodge this year for exhibition at an event. It should be fun. I have pulled with my other 4x4s before, but my Dodge should do much better. :-laf
