Westach combo gauge????
Turbo Silencing Ring?
Injector question?
Just wondering--I looked through many archives and haven't heard anyone mention the combination Boost/EGT gauge that Geno's Garage sells. (Westach) makes it.
Is this a reliable gauge? Any problems?
I'm thinking about using this gauge and mounting it in the little cubby-hole by the cupholders of my 97. The gauge comes with the mounting kit for that spot.
Any experience with this gauge? If so can the SPA combo gauge be mounted in the same spot I mention?
97 2500 Reg cab 4WD, Emerald Green and Driftwood, 3. 54 gears, 2" Daystar Coil Spacers, 315/75/16 AT BFG'S on Alcoa's, Trailmaster SSV shocks & SSV steering stabilizer, K&N, stock, oh yeah--no silencer ring
K. Kinion
They're top of the line I think, I use them in my 97. Look them over here & order their free catalog. www.westach.com
Locomotive Engineer/Red Ram Driver! 97, 2500, Auto,3:54, 2WD, Re-sale Red, Loaded w/Leather, Diamond Tread running boards & box, Bumper guards, "Bull Ring" tie-downs, Front bumper guards, Clearance lights, TST 230 HP kit (slid forward 1/16"), Missing silencer ring, K&N, Combo exhaust temp & boost gauge, Eng. & Trans. oil temp gauges, 3 Pos. Lock up switch.
I have had one in for 170K. Changed the probe at 120K. Great gauge. Even see they have a bomb version now (boost to 50).
jjw
ND
My only complaint about the Westach is nighttime illumination. It can be hard to see at a glance at night. Otherwise, it is an excellent gauge.
1996 Dodge 2500 4X4 SC, SLT, Cummins 12V, 5-spd. , JRE 4" exhaust (my kitty ran away into the woods and the muffler fell off!), TST 280 HP/685 Ft-Lb Uprate Kit, AFC Spring Kit, Horton Fan Clutch, Jacobs/Ram Exhaust Brake, MagHytec Differential Cover, Prime-Loc, Rancho RS9000 Shocks, Combo Gauge, K&N Air Filter, Brite-Box, Geno's finger-touch oil pan drain plug, Optima Yellow Tops, no turbo silencer ring, full-time fog lights.
JJW, why did you change the probe, did it malfunction? Just curious. On the quality of the gauges, no complaints, works great.
I bought one due to ease of instlation & I had planed to switch to autometer later on but once I learned to read the gauge at a glance I new it was staying. The lighting on mine is great + matches factory gauge cluster verry well.
95 CUMMINS W/AMSOIL 5W-30 CC 2WD AUTO W/AMSOIL ATF+4 +GENO'S COMBO GAUGE + SONY 10 disc + 1 CHAMBER FLOWMASTER +LOST cat + silencer ring + slid stock plate & k&N so far... ! member of the SETDR
Thanks for the help
I'm ordering mine at the end of this month from Geno's.
Kurt
K. Kinion
Probe failed. Was replace free of charge. Did not insert quite as deep in the manifold this time. Had erosion on the tip.
jjw
From the looks of the gauge it look's like it would be hard to get good reading on it.
Is that so?
Sam B.
97, Lamanie SLT, clubcab, driftwood, 3. 5 spicer 70 rear axle
96 Coachmen Royal 285rk 5th wheel, 11,000 #
[This message has been edited by samb (edited 02-11-2001). ]
Great gauges, easy to read. Awesome customer service.
"Roadrunner"-96 4X4 club cab-12v-auto-3. 54 gears-Amsoil bypass filter - all Amsoil fluids-trans filter-britebox-shelfit-DeeZee boards-Rhino liner-Rancho 5 speed shocks-Hellwig rear antisway & overload springs-Warn 12000 lb. winch-dual redtop optimas-combo gauge and trans. temp gauge in pillar mount-255/85R16 Kelly MSR tires-custom pinstriping- Walker muffler-Cummins mudflaps-Tuff Country control arms-2" coil spacers
Great gauge. I have had mine in now for two years, 35,000 miles. Easy to read, but I would recomend installing it on the A pillar. I have mine down in that little coupy hole and it is hard to see there when you really need it, you have to take your eyes to far off the road. I just ordered the tripple gauge full pillar pod from geno's. I will be moving the combo gauge and installing a fuel pressure and temperature gauge as soon as it it arives.
George, Perry County, PA
99 3500, Reg Cab, 4x4, NV4500, ISB, 4:10,VA box,Putco Boss
running boards, Grover air horns, Intense Blue.
