Westech sucks, Genos rocks
Old Power Edge box
Aux. Fuel Tank Question.
1 1/2 years and 3 bad fuel pressure senders. :mad: Only good news is that Genos Garage is standing behind them and replacing it again ( this will make 4)
It's getting old seeing the puddle of fuel under the truck...
It is remote mounted (thanks Grandpappy) and has a snubber
There is a picture of my fuel pressure setup in my readers rigs album.
Just curious how you have the sender mounted. I've had two Westach fuel pressure gauge (0 to 16) and 0 to 30 PSI in over 1. 5. years without any problems.
charles
Are you sensing right off the VP-44? that might be more pulses than the snubber likes. Is it off the engine? Does the bracket vibrate oddly while running? Did you allow anair pocke to stay in the line to the sender? Is there any delay time in the guage reading when bumping starter ( for 20 second lift pump run)? There should be some delay, meter vibrations should not be seen if ther is enough snubber action. Three should not fail. Westach does not make crap.
