Dont know what to think as of right now. I installed a new lift pump along with Banjo Bolts on my pickup today thinking I could cure what I thought might be a weak lift pump. Symptoms prior to this were my FMS box reading Low Fuel Pressure if I romped on it with more than 25% fueling added. The light would read almost instantly. I hooked er up to a mechanical gauge and had 14 psi at idle and with 20% fueling on the box I could pull it down to 1 psi! Bought a pump Friday from Cummins in Denver for $130. 00 and popped it in this evening with my new Banjo Bolts. Took it out for a spin and same darn thing! Low Pressure light on with fueling added!!
I installed all Banjos but the one going into the VP housing where my fuel pressure sending unit is. I need a male to male adapter to attach my sending unit hose to the Banjo Bolt so had to leave that one stock. What the heck might my problem be?? I got this sneaky suspicion I just wasted $130 on something that isnt the culprit to the problem.
Maybe I'll mount my original lift pump at the tank and run a series of pumps. What do you all think I should do?
