Benifits listed by
http://www.duramax.bizhosting.com/My_Truck/water_injection.htm
Key Benefits
Reduces IAT [Intake Air Temperatures]
Improves power output of engine
Improves fuel economy
Reduces combustion chamber deposits
Helps keeps engine oil cleaner
Easy install using common tools
OEM [original equipment manufacturer] quality and compatible weather resistant connectors.
OEM style wire loom, looks like a factory setup.
Hi-pressure system uses a pump not turbo boost, this ensures proper 'spray pattern' which is easy on the turbo blades and mixes with air better.
Unlike boost pressure powered systems, water will not continue to inject in the case of a solenoid failure, in fact only the second stage of our 'dual stage' system uses a solenoid, but that is after the pump, so if the solenoid fails open you will only get full water injection at boost pressure when the engine is running only and maybe waste some water.
Industrial grade and quality hi-pressure pump
Long lasting pump, [not a cheap windshield washer pump]
Pump can run-dry, but not recommended.
Optional tank with low water level indicator
Optional tank for various applications
Optional tanks are not steel and will not rust
Optional filter to keep nozzles cleaner.
Dual-stage system avaialble for additional cooling.
First stage for most benefits
Second stage for added benefits at higher boost levels and loads, such as when towing or going up hills.
This kit designed is specifically for the GM 6. 5L Turbo Diesel.
Other kits available for other vehicle / engine applications.
MADE IN THE USA.
Single stage kits from Only $4XX. XX without tank
