41 pounds of Road Force is a lot!
I used to own a Road Force balancer before I retired and shut down my shop. It depended on the vehicle but anything in the 20's and up can be felt by a person with a sensitive bottom. The lower profile the tire the more sensitive to being out of round. That is essentially what you are measuring when checking Road Force, eccentricity of the wheel tire package or how egg shaped it is.
If the tires are new, Michelin will always swap a tire that has too much Road Force. I've found a few new Michelins with high numbers in my day and they never refused to replace the tire...
Also, an out of round rim can contribute to high numbers as can a tire that is damaged in mounting (always obvious on inspection) or even a bad hit to a big pothole might cause issues.
