GWoody said:I had mine reflashed today, the first dealer I took it to about a week ago said they did it but I was suspicious so I went to a different one and I watched them do it, we'll have to wait and see about the mileage but the high idle feature works after this flash.
hasselbach said:How do you get the high idle to engage? did it not work prior to the reflash? is the high idle only used in super cold regions??
GEM said:How can I prove my dealer actually completed the TSB? Im not sure they did anything at all?
GWoody said:Three things tipped me off, the mechanic wasn't with the truck 10 minutes and my overhead din't change a bit, and my high idle feature didn't work. I had read on another thread that the high idle would work after this flash but that's only on the automatics.
PJ said:I just went out to my truck, started it up, turned on cruise control... nothing... hit the accel and still nothing... Did they just put a sticker on my truck and call it good or did they just omit the high idle option? They only worked on the truck for 30 min. I thought this was a 2 hour job? Anyone???![]()
Pawpaw said:The truck must be in either park or neutral and do not step on the brake pedal. With the engine running, turn the cruise control on, then press "set". The engine should ramp up to 1100 RPM.
After that, pressing "accel" or "coast" will vary the engine speed between 1100 and 1500 RPM.
Cancel the fast idle by stepping on the brake pedal, pressing "cancel", or turning off the cruise control.
Bob
phloop said:... I had heard that this reflash helped with a slow speed start problem that some one had before the reflash, I have the same problem with my truck. I do not think I should have to power brake my truck (to get the boost to come up) just to get it to move out of it's own way. Heck, my ol' PSD had more get up and go off the line than this Cummins has.
