I should clarify myself I did not mean they would break while towing normal loads. But under odd conditions like a shock load while towing heavy they can let loose. I have broken many over the years in sand and snow during wheel hop under spin out conditions not by hitting a dry spot just the axle wrap caused hopping. The ladder bars have solved this problem.I have never broken a factory zerkless joint. all broken ones have always been zerked.
The thread originator pulls a boat and a lot of spin out then sudden dry spot hits happen on most slippery boat ramps. Granted his boat is not that heavy but anything is possible. just trying to save a future problem for him.![]()
aseigworth said:If you're in an area that salt isn't liberally applied to the highways you can get away with the soild joints, here in the salt world we can't. The salt/calcium mix gets in & locks 'em up almost as quick as you can replace them. The implication that the grease hole makes them weaker is BSIf this were true I should've broke the U-Joints in my '94 before the motor mount :{ , I forgot to multiply the load by 3. New tri-axle truck cab & chassis, stacked for transport, blocking a busy 4 lane, (23,695#)(each). :--)
BILLVO said:I should clarify myself I did not mean they would break while towing normal loads. But under odd conditions like a shock load while towing heavy they can let loose. I have broken many over the years in sand and snow during wheel hop under spin out conditions not by hitting a dry spot just the axle wrap caused hopping. The ladder bars have solved this problem.I have never broken a factory zerkless joint. all broken ones have always been zerked.
