What are you Towing and Hauling?
Tandem towing in Pennsylvania
Power Towing Mirrors
Hi all, we pull a 33ft 5er weighing 12, 600 lbs loaded with our 1995 2500 2wd stock except for a Jacobs exhaust brake and a K&N air filter.
a little slow on the grades but no problems. Planning on putting in EGT gauge and a Boost gauge from TST and a power boost kit has anyone had any problems instaling their kits
24' Dutchmen, about 4500#, truck doesn't know it's there.
16' Lowboy with my 1966 Massey Ferguson MF150 High Crop Tractor w/ Perkins Diesel
'96 Regular Cab, 118k, SLT 2WD auto 3. 54, Vista topper, Pillar-mounted Autometer Boost/Pyro, transmission temp and oil pressure guages under dash, starwheel spun
28' Sunnybrook. 16,700 lbs total. No probs.
2k, 30k miles, QC, SB, 4x, 6sp, 3. 54, 285/75r16 bfg/at, stock air cleaner (reliable), silencer ring "in" (runs better), Sunnybrook 28' fiver, 16,780 lbs. 18mpg (unloaded), 12-14 mpg (loaded). VA, DD1's, PS Boost module & elbow, BD brake... also, Nitrous Oxide piped direct into the block (stealth - to keep the warranty), 10 gallon per minute fuel pump, ECM right out of Don Garlit's Top Fueler (he gave it to me) (for letting him ride in my truck), Super Modified DD1 Injectors ("Hand Honed" with a 1/4" reamer & my 12v Makita). :) More BOMBING to come. .
A 1927 International fire truck to parades and shows in my local area.
'93 D250 CC 210hp nv4500 5spd straight exhaust grover air horm
Hey to all!
I mainly pull horses & wood for heating the home.
Anyone got a pic's?
94 2500HD 5sp 4. 10LSD 4X4 ABS w/GearVendor OD, K&N Oval w/ Pre-Filter, Straight Exhaust, Geno's Fumotovalve, AW-Direct Idle Controller, Mag-Hytec Rear, 123K miles. NRA Member. V1.
[This message has been edited by mikepvg (edited 02-23-2001). ]
Ummmm - anything I want too! #ad
I've had bigger loads (30,000 lbs - front loader on a flat bed with a pintle hitch) but this is the biggest one I have a pic of.
[This message has been edited by Steve St. Laurent (edited 02-23-2001). ]
Used to pull 10K 30ft Hitchhiker II fiver. Today we ordered 35ft Alpenlite fiver that should gross around 12. 5K. In about 6 weeks we'll see what happens.
2001. 5 White 3500 Quad Cab 4x4 Sport SLT+, ETH/DEE, 4. 10 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, Tekonshs Sentinel Brake Controller, ICOM 706MkIIG HF Radio. Preparing to add Guages, Line-X, 20. 5 Pullrite Hitch, DEE-ZEE FX Running Boards, Exhaust Brake,(maybe more later). Pulling 99 Hitchhiker II 30RK fiver and 2001 Alpenlite 35RK fiver on order.
Ham Call: AF9W/7
I tow a 26' Prowler 5th weel and my 22'boat behind the Prowler. Combo is 67'long and weighs about 19,500#. A CDL is required and I have never been bothered by Highway Patrol.
95 Ram 3500 Reg Cab Dually,5 speed, 3. 54 Dana 80, Gear Vendor,TST 235/605, Jannetty 4"exhaust,Psycoty K&N 880,Prime Loc, Pac Brake,Valentine One, Full Gauges..... ect... . ect
I haul 5 dirtbikes and 2 sand rails... . But most of the time I'm hauling A$$.
·1999 2500 QC LB Auto 3. 55 4x4
·Armorthane Bed liner, A-pillar gauges, RE-0880, EZ, 275's, Husky mats, strait pipe
See below.
'99 D3500, auto. ,2WD,3. 55 LSD, all options, Banks Power Pack w/K&N filter, '99 40ft. Alfa Gold Triple-slide 5'er
I pull a 36ft 5'er Dutchmen Supreme Double slide-out 8800# dry and between 10000 to 12000 loaded. Having all kinds of FUN!!!!!!! Good luck & have FUN TOWING.
2001 2500HD Quad Cab SLT LWB, 4x4, Cummins, 3. 54 gears,
Deep Garnet Red, Agate, 4w ABS, tinted windows,
Camper and Trailer tow packages with trailer towing mirrors,
HD transfer case, snow plow prep, cab lights, travel conv group,
mopar nurf bars, Downey SST cover, Bed liner with fifth wheel hitch
Power driver seat with power lumbar,
loaded loaded loaded!!!!!!!
24 Ft. Nash 5th
26 Ft. Cabin Crusier
Other - 5th's & TT's to 36 ft
50 K per year
Y2K RAM 2500 4X4 QC LWB Patriot Blue 5-Speed 3. 54 LS rear end, Trlr. Tow & Camper Packages, Westin Nerfs, Isspro Boost & Pyro gauges in a dual Pillar mount and DC Mud Flaps. Stock, ALMOST (so there is no mis-understanding, ALMOST refers to my Westin Nerfs & Isspro Gauges).
[This message has been edited by ldg (edited 03-17-2001). ]
Picked up the truck today. The first thing I hauled was a new bicycle for my 25 year old daughter's birthday. I use a hitch mounted bike rack. I hope it didn't overload the truck. Performance seemed good.
Ken Lenger
2001. 5 2500 QC 4X4 SWB SLT, ETC/DDX 5 Speed, 3. 55 (no antispin), camper group, trailer folding mirrors, RBR CD/Radio, LT265/75R16E AT OWL tires, trailer tow group, Patroit Blue / Agate, Westin CPS Step Bars, Jordan Utlima Brake Controller/
Replaces 98 Jeep Grand Cherokee V8 which is for sale.
Trailite 21' Travel Trailer, ~4000 lbs loaded.
93 Terry 29L by Fleetwood
Ron
'96 4x2 2500 Garnet/Driftwood Auto,3. 54,K&N,Cobra,Westac guages combo 50psi boost/egt, trans temp. on AutoMeter full piller duel pod, 93 TT Terry 29L,'84 VW Rabbit diesel,
I'm pulling a 26' Tahoe 5th wheel. We're leaving for our first real trip on Wednesday (going to Disneyland for spring break). I'm anxious to see how the truck pulls both over the passes through Colorado and along flat highway.
2k 3500 white Sport, QC, 4x4, SLT+, auto, 3. 55s, EZ, K&N, 4" exhaust w/muffler, 14sq. cm Holset turbine housing, Westach gauges (EGT, Boost, transmission), Line-X liner, Reese 15k 5th wheel hitch
87 Grand National on an open trailer (for now). Enclosed trailer in the future.
94 Dodge Ram Cummins Turbo Diesel (owned since new) warmed over by Auto Wurks... 15. 18 @ 86mph on 285/75/16s
10 second 87 Buick Grand National
11 second 87 Buick T-Type
Exhaust Driven!!
