My point is, a stock head gasket with a stock head is just that. Stock. No 0 ring, and the bolts will hold what the stock gasket will take. 125 lbs torque on the bolts, is all the same, no matter what you have in the block for retainers. Bolts, studs, c-clamps, whetever you use. We have had boost is the 40lb range blow gaskets, but the timing, a flat head, and torque is the issue here. The stock bolts have proved to hold up to high boost when torque properly. I just wasted the head gasket on my 3500. I replaced it with the stock one. Boost never gets over 36 lbs. Timing blew that one. I have the HX 35 with a 14 housing. EGT's are never an issue, the timing was to great for the constant torque the engine is under towing 15K lbs.
Let me ask you this. When you have the head O ringed, do you install the stock head gasket? Why, and what would work better? What I'm asking also, is when you say something, is it what you "know" to be, or something you read or was told? Just because the studs are installed, does not mean the head gasket issue is over.
The old saying goes here, "it ain't what I know that concerns me, it's what I know that just ain't so".
I guess I need to bow out and let you folks have a good time.
C' y'all
. . Preston. .
