What boost pressures will Arp studs hold with out O-ringing the head for now?
Detroit Series 60 turbo - Twins?
Building the ultimate towing truck.
I belive the original topic is dead or shall I say all points are taken. So im gona hi jack this one.
Doug do you think the ps 62 I run needs to be set higher than 45 psi or is that all its got I have seen 52 with it but don't want to spin it too hard if its not nesssary. Also being a PS dealer can you shed any light on how much ball park it is to be upgraded to SPS and whould I appreciate the diffrence. THANKS
I would expect the 62 to make max HP around 40-45 psi, most guys try and run too much boost. But by the same token you are not going to hurt anything running it at 50 psi.
Also you have a pm on the SPS62.....
Doug
