What Do These Codes Mean
Pac/Brake problem
Air bags?
I think these are the right codes off of my truck. I just put a new check engine bulb in so I could get the codes for my overdrive and ABS not working. I have a 92' D350 and I got the following. 1-2, 2-4, & 5-5. Can someone help me out or tell me if these are not even the right numbers. I turned the key on and off 2 times then left it on the 3rd time. I then counted the flashes. and put the dash in where there was a puse. Thanks Bill
1-2 =12 Power interupted to PCM (battery recently disconnected or PCM reset)
2-4 =24 TPS voltage too low or too high (out of adjustment)
5-5 =55 End of codes
Thank you very much. I have recently unhooked the battery to put on new terminals and clean everything. I think my overdrive solenoid is unplugged, at least that's what the guy I bought it from said. He had them leave it unplugged when they rebuilt the transmission, because the O/D switch was broke. I have since replaced it and I am changing fluid and filter Tuesday. Along with raising the line pressure and adjusting the bands. I hope to find it unplugged, if not I priced a new solenoid for $41 at the stealer. Thanks again, Bill
