I have an M1028 CUCV K30 and all of the negative comments about the 6. 2L above were true when I first got it, then I discovered
www.theDieselPage.com and Banks.
After many upgrades and some R&D I conducted with Gale Banks Engineering, I ended up with an engine that my friends describe as a very strong 454. The recipe calls for a Banks 6. 9/7. 3 MHI TE06H turbo boosting to 20psi, intercooler, DB2-4911 calibrated inj. pump (overfueled to 76mm3/stroke) and 6. 5LTD injectors. Timing was retarded to 2. 6* BTDC @ 1300rpm.
An important note: a real CUCV block has a high nickel content, which will prevent fatigue cracks in the mains.
You can buy 300-400HP 6. 5LTD truck engines from Peninsular and others and boy do they like to rev (detroit diesel v8 influenced design), mine was governed to 4100rpm and it would hold that for hours on long freeway runs.
I get 17-22mpg with a seriously upgraded 700R4 with the current configuration.
However, my lust for high torque has created a need for a more bulletproof platform, so I'm going to convert to a 6BT with NV4500 and NP205.
The stock M1028 is a K30 on steroids, GVW is 9400lbs, Dana 60 full float with limited slip up front, TH400, NP208, HD drive shaft, 14 bolt full float detroit locker in the back, 30% stronger frame, 24v starting system, 12v electrics everywhere else, helicopter starter takeoff for firing up hueys in the field, twin 100A 12v isolated ground alternators (relayed in series to charge the 24v battery setup - the 12v is produced tapping one battery and the 12v glow plugs draw upto 15v from a resistor fed by both batteries in series).
