What do you think of this Diesel Mower???
Pulled an International today
Need help!! How to set timing on Powerstroke
Hustler makes the best (non-greens ) mowers in the world - and this new diesel looks great... ...
http://www.hustlerturfequipment.com/products/szDiesel.html
Traction Drive System
Type Dual hydrostatic. Individual pumps power two directdrive
wheel motors. Hydrostatic system operates on 10W40
motor oil.
Transmission drive (oil) cooler for increased system life.
Pumps Two variable displacement, axial-piston type. Each
pump powers one drive-wheel motor. Hydro-Gear BDP21
Pump Drive Micro V-belt drive from engine crankshaft
Final Drive Direct-drive high-torque wheel motors. One for
each drive wheel. Hydro-Gear BPM
Filter 25 micron, spin-on type
Ground Speed Infinitely variable: Transport 0-15 mph
(0-22. 53 kph), Mowing 0-10 (0-16. 09) forward, 0-7. 5 mph
(0-12. 07 kph) reverse
Steering Twin-lever steering provides independent control of
each drive wheel. Speed, forward, reverse, brake, and turns
are all controlled with hand-operated controls
Turning Radius True zero degree. Turns within its own
length. Counter-rotating, independent drive wheels
Vaughn MacKenzie said:
I didn't know Cat made a 34 horse diesel. Is it a 3-banger?
They were marketing either Detroit or Perkins small displacement diesels with a CAT logo.
SRadke said:
Hey Vaughn, how does that compare to the 'ol Briggs diesel :D
-Scott
Briggs & Scrap-Iron was marketing a range of Daihatsu engines. Many years ago they bought Lombardini, who made single cylinder diesels, but they are long gone.
I have to disagree on Hustler being the "best non greens mower," but Ferris has been using the Cat for a year or longer and I have not heard of any complaints. Most of the diesel powered mowers use the Diahtsu/Briggs (Exmark, Gravely) engine while some use the Yanmar (Turbo charged on the Dixie Chopper). In my opinion the Kubota diesel is the best but I don't like their mower.
No doubt Hustler is a top of the line mower but the 15k price tag for that thing is a little steep.
I think it is too coool! That radiator would make a Cat skid steer jealous! :--) Around here they are $13,500. That is why I will be getting a Hustler Z with 25HP Kawasaki instead. ($7500) I here the same thing about it being a Perkins. I got no problem with that though. I may have to try one out for giggles when I pick mine up! :D
