In response to Tim's post and trying to keep to the subject matter at hand, I believe I was quite clear in targeting my response to published ratings considering the market segment of ½ tons. There are a myriad of calculations that one can and should go through to assure a safe and proper tow set up, including the relationship of GVWR, actual vehicle weight, GCWR, trailer actual weight, and trailer GVWR. There are way too many variables for the various setups one might use this for to go into specifics. If it works for you and your situation, great, if not and you’re not in the market for a ½ ton, so be it. I was quite specific as well to the ability to tow a 5-7k bobcat, as how this thread started.
Here is more information specific to the Titan for consideration.
GVWR 6,522
Weight 5,460 (as tested by Trailer life on a well equipped 4x4 unit, two passengers, & full fuel)
Payload as tested 1,062
Curb weight (4x4 without passengers) 5,106
Max payload 1,416
GCWR 14,822
Max tow rating as tested 9,362
Hitch weight max 930
The limitations here (Payload, hitch weight, & GCWR) are actually fairly consistent with all topping out at approximately 9,300 lbs tow capacity, considering 10% (930lb) tongue weight. Actual truck weight (5,460) plus trailer weight (9,300) equals 14,760, which is just below the GCWR of 14,822. Tongue weight of 930 comes in less than the available payload of 1,062. Does this work for your particular situation, probably not, but it wasn’t the point of this thread. Everybody’s situation is different and some people may just need to pull that 7k bobcat or travel trailer.
As far as Nissan is concerned, it’s no secret that Nissan builds some of the best gas engines in the world, constantly winning awards from the likes of Wards and auto publications. A ½ ton truck might not be the right tool for the job for you personally, but it doesn’t mean that it is not a very solid option for those who are in that market. If you don’t like Nissan that’s fine and just your opinion, but it doesn’t mean it is not a very stout truck for its intended market. It’s not meant to compete against ¾ ton or 1 ton trucks.
