Ok im in the buying market and i cant decide between the 12v and 24v
I like them both very much and am very knowledgable about them both, however
the things that will remain the same is that either truck will be manual with 4wd
now with that said
is it possible for either or both trucks to get decent 1/4 mile times say like (13s-14s) range with just bolt on?
can it even be done without twins or internal engine work?
If it helps, if I did get a 24v it would be ext cab and shortbed
if I could find that in a 12v then definitely but if not I havent decided the body yet
I read so many threads but havent seen many on what times people are pulling with what power etc
Also both manuals would be the 5 speed (no 6 I heard they are hard to shift fast)
thanks alot guys
thanks alot guys
