The RASP is basically a mechanical gear driven pump that runs off a pulley mounted to the harmonic balancer plate. It runs in parallel to the stock lp.
When you start the engine, the oem lp starts up to 8psi. As the engine begins to rotate and the RASP pump starts pumping and goes above 8psi there is a pressure switch that turns off the OEM lp. IF the RASP belt breaks or the RASP fails for any reason the RASP psi drops below 8 psi the pressure switch turns on the OEM lp.
Basically the OEM lp runs for about 1 - 3 seconds on engine start each time you start. That way you can also make sure the OEM lp is functional each engine start.
The RASP has no filtering system. It is a fuel pump.
I went to the RASP because it is developed by DTT and they do an extremely good job when they do something. It mounts to the oil pan front 4 mounting bolts on a billet plate adapter. The mounting system is super easy to install and easy to adjust the belt tension. The belt is a cog type belt. When I ordered a spare it had to come from Gates Industrial division.
I think the best feature is the more rpm the more fuel volume and pressure. It has a bypass valve you put on a T just before the VP inlet to bypass excess pressure back to the tank filler line. You know exactely what the VP is getting. The whole thing is mechanical and extremely well built.
The bypass valves are adjustable if you want a different setting. I left mine alone and get 17 psi max to the VP empty and pulling my RV (13k) I get 16 psi. At idle at a stop light in gear (ETC) I get 14 psi. Out of gear I get 15 psi at idle. I like the idea that the VP bypass valve is generally open somewhat and the excess cooling fuel is bypassed back to the tank.
Ollie Poole (
www.powerbypoole.com) is one of the distributors and knows a lot about the RASP. Ollie is a good personto deal with as well.
I ordered my RASP without the plumbing kit as I do my own plumbing. Was not hard to plumb at all. Ollir does sell a plumbing kit I think.
The only maintenance is to change the belt about every 50,000 miles (3 years for me)
I had a problem with my OEM lp for a week or so and found out that the RASP would start the truck no problem by itself wothout the OEM lp. I liked that because I could still start & run if the OEM lp totally crapped out.
I bought it, of course I like it. You quit watching the fp gauge like a hawk.
Bob Weis
