What injectors are these?
Mobil Delvac 1300 15w-40
Step/Nerf Bars
Are you sure you posted the right # ... can't find that in my cross ref book ... . can find the 753 ... but not the 743 . .
Life is Good
Keith
More numbers
I got some more numbers off the injector, the body has 0131 and the tip is 9492. I hope this will help.
thanks
first gen injectors have smaller tops on them where the lines screw on. Check your 2nd gen and then check the ones you have. This will get you closer to the answer.
Don~
Try running a search using those #'s. Somebody put up injector #'s on the site a while back, maybe that's one of em?
Eric
PS Mine (from Piers) are the same but end in 715, not 743.
I've checked through all the ref books I have ... . and this is what I think you have ... . Cummins injector part # 3930131 which acccording to the book is Bosch part # 0 432 131 005 with the Cummins nozzle # 3929492 Bosch part # 0 433 171 435 This injector is for CPL's 1889 and 2063 with a nozzle opening pressure of 240 bar. This is a 7mm nozzle and will fit in the 2 gen engines ... . but I wouldn't recommend it as the 160 and 180 hp engines have an opening pressure of 260 bar.
I couldn't get an application for the CPL . . because my CPL book is too new and these CPL's are out of production. Someone with an older CPL book might be able to find out what application these CPL's were ... Hope this helps ... .
Keith
Thanks Keith
I got them real cheap and my try them for fun. I have the 215 hp engine and if I understand you correctly they are the same hole size (7mm) as the 160-180 hp engine. Is this correct or not.
Thanks again
Yes ... . but I suspect they are for a much lower HP rating ... . I doubt they will perform well in your 215 ... . you might want to measure the nozzle lengths ... to make sure you use the right thickness for the copper sealing washer. This basically determines where the spray pattern hits the combustion bowl in on your piston ... . Good luck ... let us know how your experiment turns out
Keith
(edit) I would also measure the nozzle diameter just to make sure they are 7mm nozzles ... .
