RSchwarzli
A few question:
1 - If you were to be buying a new IC for your truck, what would you get? Banks? Spearco?
2 - For those of you that have purchased aftermarket units, was it worth it? Did you see that much of a drop?
3 - Is there anywhere that has the flow and EGT number drop on the same engine so that everything is consistent? I dont like advertising info, I want REAL info.
I ask as I need to put a IC into the 1990 this winter. I am heat soaking the current one. But I am not sure if it iw worth spending the money on something good, or just getting a stockers and slapping some fresh paint on it. :-laf
Boost numbers will be around 40-45 psi and heavy emphasis on towing, not stop light racing.
Robert
Robert
