What is a CRUSH PLATE??
Another bad U-joint
TST CR Dyno Graph
OK, dealer has to have my truck until tomorrow because the crush plate for the rear end didn't come in until late this afternoon... if I may ask. . what is this crush plate????
crush plate or sleeve or what evr u want to call it is a steel space that goes between the inner and out bearings on the pinion. as u tighten the nut it will allow u to load the bearing without stopping them from rotating. a properly set up crush sleeve will exhibit some where in the area of 20inch ppounds of drag on a properly loaded pinion.
