2nd Gen Non-Engine/Transmission What is bad, control arm or bushing (sliding left/right)
Engine/Transmission (1994 - 1998) Pilot Bearing?
2nd Gen Non-Engine/Transmission Heavy Duty Shock Absorber Question
All,
I have been getting a "Clunking" noise/feeling under my feet and found that my upper control arm is sliding to the mount both left and right (PS to DS). Its obvious that the control arm is the moving item. I'm curious if this is a problem with the bushing or the control arm. Just so I can get the right part ordered. Money is tight having just transfered to a different branch of the military so I can't do my normal overkill replace it all approach.
Oh, and it appears that the bushing is 100% intact and not damaged, other than the components are not bound together...
Thanks,
Corey
The bushing looks 100% intact and is not moving, the actual control arm is sliding on the metal outter surface of the bushing... (Unless this is a metal inner surface of the control arm... )
Corey
