What is going on with my truck??? FIXED!!!
After re-installing my turbo Sunday night(had to replace oil return gasket) I took my truck for a spin. About 1-2 miles down the road, at about 60-70mph the truck acted as if it stalled, for just a second. I let off the throttle, then it did it again about 5-7 seconds later. The best way to describe it is, when/if you start to run out of fuel, the truck almost dies for a split second. Unfortunately I have run my truck dry before and this is EXACTLY what it felt like. I thought maybe it was just a fluke but it did the same thing again this morning on the way to work. One right after the other, only two times, and only for a split second... . and about 2-3 miles away from home Maybe air in the lines??? But why happen now, for the first time in 120K miles... and why right after I had my turbo off??
