KevinO said:It's the vacuum pump
Hercules130 said:There is no vacuum pump on 3rd gens.
diesel0904 said:i think it is the fuel pump priming it should go for about 4 seconds and click
BLACK PEARL said:My guess is the grid heat on the intake. Does the noise stop when the grid heater light on the dash does out?
rbattelle said:Are you sure you're in ACC (which is accessed by turning the key backward)? Or are you in "RUN"?
-Ryan
mwhals said:You might have figured it out. I put the key forward instead of backward out of habit due to our car and my former truck working that way. I probably am in the "on" position. I will reverse the key direction for now on when just playing the radio.
Thanks!
Mark H
MWilcox said:The clicking sound is there with any common rail cummins when the key is turned on to acc.
