What is the stock clutch rated at???
EGR failures
Rear Brake Shoe Update
Brian-
Yeah I have a 3500 so maybe all that extra traction is affecting me. Luckily my tires are about gone so when they go bald, I'm going to try to light them up again.
I just got back from a trip towing the trailer this weekend. Those DD II's ROCK. Hills that I used to have to downshift into 4th I was only half throttle on. On the steepest hills I did some WOT tests, EGT's never went over 1000, 30 pounds of boost and feul pressure never dipped below 9 PSI. I looked over at my not as amused wife and said "just think I still have another 120 to 150 HP not being used". :rolleyes: I did not use the UFM box at all due to not needing it. Ken:)
I have just an EZ and pull a 4300lb trailer and can slip my clutch EZ. I'm a real soft driver and don't abuse stuff at all, mostly short shift this thing. Soon as I hooked to this trailer for the first time, I shifted from 2nd to 3rd (@ about 2200 rpm) and zing went the clutch. I think it all depends on your particular truck. It's obvious, some have better clutches than others
not entirely impressed
i rolled 80k miles today. Almost a month ago -- at 76k-- OEM clutch took the big crap. I only have mild mods but some say i still have those testosterone driven driving habits that some of us "damn kids" seem to have from time to time. After a lot of cussing, a friend - paid in beer and Pizza- and i had a centerforce dual friction installed. It was recomended by the local 4x4 shop, Southwest 4x4(thanks guys), that it would do well in my application, its limits being possible failure on the pulling track, but mine sees mostly roads and wet fields.
The centerforce is broke in and impressivly better than OEM, and with the same pedal.
i got this truck used but at only 26k at purchase, i cant really blame that one on the "guy before me"
I couldnt make a fair tourqu guess, but from boost pressure and towing ability, i would GENEROUSLY give mine 250 horse.
Am i suprised at the failure?-- No. I do think it should have made it at least to 100k though... . Dads is 100% stock with like 190k on.
my only dissapointment is that i had to spend the mony i saved for smoke stacks. Oh well, i guess ill get those on next spring... :rolleyes:
ps-- gross weight about 23000- 24000# alot of times with the oliver 99 on the trailer. dad pulls the same loads i do, and before my truck came along in y2k he pulled both tractors to the shows and tractor pulls-- he could weigh nearly 30000# on any sumer weekend...
his is a `94 2wd 5 speed, 4:10 gear and stock 175 horse.
stock clutch slippage
It seems like mine slips a little with just the b&d module, if i really get on it. I know i need the south bend
