Precision Diesel Injection and Turbo Inc.Originally posted by WadePatton
Where is the best price on the overflow valve?
It won't work to have a valve in the return line because the flow of fuel varies with rpm.Originally posted by DMC
I was reading through this thread and got to thinking about the overflow valve. And had a brain storm. Why not put a needle valve in the return line in place of the overflow valve, and regulate the fuel pressure that way? Of course if you do this you need a fuel pressure gauge to set the valve and monitor the pressure. This would put an end to the high cost of overflow valves. And might improve fuel mileage as a result of steady higher pressure at higher rpms.
Any body got any pros or cons on this?
Thanks
Don
Originally posted by AKnight
I've got a 2002 24 valve 6 speed. It is stock except for K & N air filter. I called Genos to order the Westech fuel pressure guage. He said the 0-16 psi guage would be okay for stock. I am not planning to do any modifications to the engine. Also what pressures should I have. Thanks
