2022. Much has been written but nothing is very clear.
What are the power ratings?
Upper and Lower Radiator hoses are listed different part numbers.
Same with radiator and the actual shroud.
Figure the Radiator would be as it's a different transmission, was kinda surprised it lists different hoses and shroud.
Highly doubtful. I believe the injectors are different between '19/'20 and '21...I know they are between '21 and '22, along with the feed tubes. But I'd imagine any rating increases would have required significant testing above and beyond the normal CP4-to-CP3 conversions, plus perhaps a re-certification for EPA.I wonder if when they are installing the 21'+ truck injection system and re-programming on the 19'-20's during the recall if the HO's will be bumped from the 400/1000 to the 420/1075 since I assume the other hard parts are probably the same.
...no it's not, it's a CC. There's no SO/HO version of the CC engines. They do share the Aisin transmission (and flexplate), and maybe they share some heavy-duty cooling hardware, too.......but the DP 5500 is LO (Low Output)
