Still trying to figure out how to get rid of excessive body roll going into turns or tight curves and firm/tighten what appears to feel like a loose front end. I know some of this can be expected, especially with any lift, but, not to the extent I'm experiencing. The 6" superlift went on about 30K miles ago and I was suprised at how tight the truck drove. However, in these last 10-15K miles or better, it think the springs have relaxed/weakened. According to superlift, the coils will relax after some period, but, will still retain the 6" lift height.
As of late, I've installed the dual Bilsteins up front, SSI adjustable trackbar and replaced the drag-link tie-rod (at the pitman). The other tie-rods are tight and the upper/lower ball joints are in similar condition, as told to me by two shops. I inspected for play at the steering box (both ends) and did not see anything alarming. Also, I replaced the grommets at both sway links and did not find any wear at the bar mounts. Although I feel I made some improvement with the Bilsteins, I still have not corrected the problem.
Any suggestions on where to go from here? thanks
