What oil for air tools?
Getrag
Engine turning tool
Just wondering what a good air tool oil would be to use. i've got some expensive air tools that i want to protect and wondered what brand or type that others use.
Lubriplate air tool lube
Royal Purple air tool lube
I use those. Marvel Mystery Oil works well, too.
thanks for the replies. i think i'm going to give the atf a shot. the big problem at the shop is moisture in the the air lines. i try to blow it out with the air gun first, but it can still be a pain. hopefully i can talk my boss into setting up our compressors with air dryers and oilers.
Water traps sure seem to eliminate a substantial amount of the moisture issue. Used in conjuntion with an oiler your tools will definately see longer lifespan.
