Cummins4life,
Good choice, #10 will get you started and you'll be happy with it for all but the more extreme power needs. Timing will help the smoke a little (try setting to about 15. 5 - 16degBTDC), there's instructions on the web somewhere, maybe someone can point you in the right directions. If you have a shop manual (the big one, not Haynes, although, I think it too has some instructions, just not as extensive), all the info you need is in there. You can get the tools from Snap-On for about $250 vs. the Cummins tools which are over twice that. The tool kit has served me well. I don't get much smoke unless I REALLY lay into it (dyno, drags, etc) going down the road with 370 injectors, the #10 plate slid almost all the way forward, 191 delivery valves and Piers 35 hybird turbo.
Howard,
I found out the reason I am not dynoing like I thought I should (see back a few comments on this post) and it had nothing to do with the governor lever adjustment! I found a socket and extension jammed in the back of my intercooler betweent the cooler and the "A" bracket that helps support the cross member. It made about a 3/16" hole!!! :--) Apparently the previous owner did not practice good tool control. Maybe I'll send it back to him with the bill for my time PULLING THE ENTIRE FRONT END APPART!! It's fixed, we'll see how she runs on the dyno two weeks from now!
