jabird
The high idle feature as listed in the TSB 18-019-01 re-flash, will yield 1200rpm idle and also shuts off 3 cylinders if the intake air temp is below 15*F. I had mine re-flashed over X-mas vacation and this morning is the first time it was cold enough to engage the 3cyl. idle. MAN,, I see what every one was talking about now... it sounds wicked!!!! The engine knocks like it has bad fuel... the 4" BD exhaust cracks like I had an exhaust brake turned on. But let me tell you, it was about 5* and after idling about 10 minutes, I drove 1/2mi. and I was over 150* on the temp gauge. It is worth it... make sure you tell them to turn on the 3cyl. high feature though... and make sure they re-check it to see if it saved the changes in the ecm, I had to go back to have them re-enable it. Hope this helps. For more info look at the oem high idle feature post. Oo.
p. s. my mileage never changed
