Originally posted by HeavyHauler
... anytime I run mine over 2000, I get loads of smoke...
That doesn't sound right. You should get smoke at lower RPM, when the turbo isn't spooled properly.
... to the guy that said peak torque is at 2900 on these engines. You need to recheck your figures...
How much more convincing can a dyno graph be? I think Keith would know more about the power the Cummins can make, and at what RPM it makes that power at than anybody else on this board.
... If your statement was true, our engines would be rated at some 830 lb. ft. of torque at your figure (proportionally)...
I'm at a loss from this statement. How does this work?
... It is widely accpeted that running your motor anywhere over 2000 RPM is killer to your fuel mileage...
In one issue of the TDR mag, it was also pointed out that running below 1,600 RPM was also detrimental to MPG.
Running below 1,600RPM is also known for spinning the 5th gear nut off the shaft on 5-speed trannies.
Cummins also states that running the motor below peak torque is detrimental to engine life. (Lugging)
HeavyHauler, No flames here.
These are my thoughts on the matter. I don't say what I'm thinking very often, mostly because I am not very swave of putting what I am thinking into words in a way that sounds like I am not fighting. (my thoughts come across as punches, compared to conversation)
Am I TDR'ized to much, thinking the higher RPM isn't going to hurt these motors and drivetrain?
I am confused how Cummins would say anything above 1,500 is "spinning", but then rate Marine motors for constant operation at 2,600RPM, and give the Dodge /Cummins a 3,200RPM full power redline.
My $. 02.
Merrick Cummings Jr
