What S400 for twins
Smarty download
Stock turbos stink
I want to build a set of towing twins with the stock turbo and an S400.
What version of the S400 should I use? what size wheels and exhaust housing?
I have an 05 QC, G56 6 Speed, AFE intake, Edge Hot juice, 50HP DD injectors, 4" straight pipe.
on a budget a 75mm comp wheel and the tightest turbine housing you can get will be the best you can get for towing in an S400
what about a 66mm w/ 16cm housing? Cause I have the 66mm HTT turbo and am thinking about trying the stock turbo on top of it... .
My goal is only to cool the 600hp I have now... .
On the other hand, how expensive is the S400?
weed blowers
Hey Andy,
If I was you I would junk your stock turb and run down to costco and pick up one of they're electric yard blowers, wire it through a 1000 watt inverter and use a sewing machine foot pedal to regulate the speed. I have 14 of them installed on my truck and with a stock fuel plate I made 8,152. 5hp and 26709ftlb!!! plus I can blow the grass right off my yard!!! Na, just messin with ya!!!! this is robert next door. tell fletch I am putting an 06 common rail motor in my truck, hopefully in 2 weeks.
p. s. dont really try the weed blower thing, you will blow your trans instantly!!!!! lol!!!:-laf:-laf:-laf
