I got the 01 3500 back from the shop and the new electronic fuel pressure, boost and transmission temperature (read off the line type) are installed. I know that this question has been asked here but I cannot find the answer for a stock truck. Now that I have the gauges, what should normal readings be under what circumstances?
On a semi-related note, and a bit of a rant. I have two issues with this process that I'll toss out here, as I'm guessing I'm not alone. 1. These trucks cost a lot of money. It's is a shame that we have to go spend almost $800 (incl' shop install) to buy three gauges that the truck should have had to begin with. This isn't an issue of the company saving money using less chrome, we are talking about equipment every knowledgeable owner sees as a necessity, and no, it isn't just Dodge that does it.
Item 2 is mechanics that don't listen. When I had more time and before I owned this truck I did almost all my work myself. Because of that background I usually type a list that is very specific of what I want, and even that gets ignored sometimes. In the case of this gauge install, I talked to the shop owner and specifically told him I wanted the braided line and snubber I provided put in for the fuel pressure gauge. When I go to get the truck after they're closed, my wife who paid them earlier hands me the braided fuel line. Of course this means another trip. The owner is normally good to deal with and he readily concedes and says he'll install it. That's when his mechanic pulls me aside and explains that I don't need it. I point out that the line and snubber are a combined $50. 00 and that I didn't buy them to throw away money. I proceed to show him the manufacturer's document where I highlight that not using these parts will void the fuel pressure gauge warranty. At this point I see he's getting an attitude. He tells me with some measure of patronization that this is only for high performance applications. I respond, "Well, it appears you and the engineers that designed this system and tons of owners of these trucks disagree. " I say, "I'll follow your advice". This brings a smile to his face. I then say "Now all I need you to do is sign a written document explaining that you know the manufacture's recommendation to be wrong and that you will take financial responsibility if the mfg. determines the gauge was damaged as a result of instructions not being followed. " he didn't smile and the line will be installed.
