Engine/Transmission (1998.5 - 2002) What should I do for more hp?
2nd Gen Non-Engine/Transmission New Tires - Steering Weirdness...?
Engine/Transmission (1998.5 - 2002) HX40 TUrbo Pricing
I currently have the RV275 injectors, EZ box, and SB clutch.
Last time I dyno'd around 290 rwhp.
I'd like to get to around the 350hp range.
Brother-in-law bought a Duramax so I thought my current setup might need a bit more if he decides to do something sneaky.
So what's my best option to the 350 range (or maybe a bit more;) ?
Since Rip is local I thought about getting a Edge Comp and 4" exhaust from him, but don't know if there is a better or cheaper way to add the hp.
My . 02 cents
Bigger Showerheads
Major fueling Box (Comp, TST, Blue Chip, etc. )
either would get you there, both would get you beyond. running bigger showerheads and a major box you probably should upgrade turbo.
If you want 350+ go with at least DDII's and a wire tapping box (comp, tst, blue chip etc. ) With my DDII's, a TST on level nine and stock turbo with a K&N in the stock box and 4" exhaust I got 366 hp. Only problem with this setup is I can bury the Pyrometer to 1500*. I know a turbo upgrade is needed at these levels so plan on one. Just my $. 02
There are a number of recipes to get you there (350HP)
A race box (drag comp/ddufm. PMAX comp) and 275s will do it.
A regular fuel box (comp, pmax) and dd1s will do it.
So will a timing box (ez, van aaken, all the clones) and DD3s
Lots of options.
HOHN
How about:
Mega Mental Injectors
Major Fueling Box
Twins
Propane
NOS
Ummmm... ... yeah..... that should be around 350 hp :D
(Per Tire) :D
Sounds like your on the right track, got your clutch and gauges done. DD2's, boost elbow, and a comp should get you there. Might look at some kind of air box or open up the stock one by drilling holes in it. I prefer the AFE, but theres a lot of options out there.
Robin
