Engine/Transmission (1998.5 - 2002) What should my 1/4 mile & HP numbers be?
I just had all my mod's installed a couple weeks ago. I haven't dyno'd or been to the drag strip yet. Anyone with the exact same setup have numbers for me? I've heard 435RWHP and Mid 14's... does this sound correct?
I have a similar setup, and I run low 14's. I usually run 14. 04 - 14. 08 at sea level, depending on the temps. You should running a little faster because of the drag comp (I have the regular comp), and the 4. 10's. I would take a helmet to the drag strip, because you need one if you run quicker then 14. :D
Paul
Yeah you'd be lower the mis 14's. Heck I ran 14. 7 stock w/ drag comp. Of course I have a DTT Billet Trans, lock-up switch, lost muffler, air filter.
I almost have the same setup with dd2's and the hybrid 35/40 and 295's with water/meth. I went 13. 8@104. . at 900ft lost the head gasket. . Stayed in it till the end. . So you can hit low 14's I would think. .
With out the water/meth the truck did 387hp at 815tq.
Hope this helps
