I have a 2 floor garage built into the side of a hill. 28X28 with 11' ceilings in the bottom garage. I heat the bottom garage which keeps the ceiling warm. The ceiling is the concrete floor of the top garage. This prevents water that might come off my wife's car in the top garage from freezing. I can't have her slide on the floor and drive out the other side of the garage, its 12' down!
I had a heater like your looking at in there when I first built the garage. I had water collecting on the ceiling (metal pan which is floor of top garage). I researched it and found that for every gallon of kerosene you burn you add something like 5 gallons of water to the air.
I then switched to 60K BTU propane forced air heater,with a duct that crosses the ceiling of the shop with several vents in it.
The thermostat would only go down to 45 at the lowest. I burned out a 100 lb tank of propane in 2 weeks.
I yanked that heater out and put a used 100K BTU oil burner in with a 165gallon tank. The first winter I think I burnt 100 gallons of oil leaving the thermostat at 45 all the time. Last winter I switched to a thermostat that I can set at 35. I burnt 45 gallons last winter!
When I need heat, just turn up the thermostat and its what ever temp I want within a couple minutes. Maybe the heater is over sized, but It was free. When I need heat it brings the temp up quick.
If doing it again, I think I would build the radiant heat into the floor and use Oil to heat it. Plus I would insolate the block. Don't know why I never thought of it while I was building it, now it would cost a fortune to insolate it.
