Straight from shop manual:
EXHAUST BRAKE FUNCTION
The VGT works in conjunction with the engine and the transmission to provide an integrated braking system used to help slow the vehicle. This is commonly called exhaust braking. This braking power is achieved by modulating the turbo sliding nozzle ring to restrict the flow of exhaust gases from the engine, which in turn creates a high back pressure on the engine. The high back pressure creates a high level of resistance to the motion of the pistons within the engine and this resistance is used to reduce engine speed and thus vehicle speed.
The exhaust brake feature will only function when the driver turns the exhaust brake switch to the on position. Once the switch is in the on position and the vehicle is moving faster than 8 k/h (5 MPH); the exhaust brake will automatically operate when the driver removes pressure from the throttle pedal allowing the engine to see 0% throttle and 0 fuel delivery.
Exhaust braking is most effective when the engine RPM is higher. The automatic transmission has been programmed to downshift more aggressively when the exhaust brake is enabled to increase brake performance. Use of automatic transmission Tow/Haul Mode improves interaction between the engine and transmission. Inputs to the exhaust brake feature include:
Coolant temperature
Ambient air temperature
Exhaust manifold pressure sensor
Throttle pedal position sensor
Fault codes with any of these sensors will cause the exhaust brake feature to be disabled.
The exhaust brake feature can also be used to reduce the engine warm up time. To use the exhaust brake as a warm-up device, the vehicle must be moving less than 8 k/h (5 MPH), the exhaust brake switch must be in the on position, and the coolant temperature must below 82°C (180° F) and ambient temperature below 15. 5°C (60° F).
My amateur opinion:
- Operation appears to be more dependent on RPMs than MPH. Therefore, since you are operating with an automatic transmission, you may want to manually control your gear selection on you shift column.
- To improve operational effectiveness, operate in two/haul mode.
- Finally, make sure you do not have any fault codes present. Fault codes can affect EB operation.
