cjohnson said:Really depends on lots of other things on the truck. We've got an 01 that runs 11. 60's in the 1/4 at 116 mph on a single charger with some spray. It will go sub 12. 50's on #2 alone, again with a single charger. That is a 4wd that weighs around 6800lb. I'm always leary of throwing dyno numbers around, I have seen a lot of instances where dyno #'s didn't equate to real world performance. That ET and mph should give you an idea, its making quite a bit of power. Anyway, to answer your question, it really depends on what you want to do with the truck. There is now doubt that ultimately it is necessary to go to a p pump to get more performance, but I think people are sometimes a bit quick to try and make the jump. A VP 44 properly set up with the supporting systems can make some descent power and pretty impressive performance.
Craig
Jetpilot said:We made 832 RWHP @ Fall Brawl this year. There is more to come with a little more tuning, 850 shouldn't be too hard and I believe 900 is possible.
Doug
Doug
RacinDuallie said:Yes impressive numbers no doubt, but how much of that is on spray? What does it spin without the bottles?
Jetpilot said:Does it matter..... Actually its a single turboed truck that makes right at the 600 mark on diesel, so around 230+ is made on the gas. This is using a stock ETC pump. We set this truck up to make power on nitrous not just diesel, I would have gone a different route on the setup for a straight #2 truck.
Doug
TGibbs said:Jet pilot, what would happen if you added propane with the NOS? More heat? Just curious because I was thinking about putting it on mine.
