Engine/Transmission (1998.5 - 2002) What to do next? (mods)
Engine/Transmission (1994 - 1998) fuel filter drain
Got the issue worked out with the new van aaken module. Now what to do next. I'm thinking injectors. What size and brand, jammers stage1, mach 1 or 1. 6's, or dpp's stage 1. what can I safely go to and still keep the stock turbo?
I ran 90hp JL [John Link] injectors for a while with the stock turbo & no problems with egt. Industrial Injection has the best injector that I have ever tried to date..... smooth idle & awesome smooth power on every set that I've tried from them. They are also cheaper than Don's F1'S. I'd say a set of 80-100hp injectors will be great. They will also be enough fuel to get you over 500hp if you decide to do more mods.
A good set of starter inj's to get you a little more power would be the Edge Jammer nozzles. They're a great inexpensive injector to start out with.
