what tool is used for a 6 spd manual transmission on a 2500 03 4x4?
isn't there a drain plug as well or do you remove the extra pto cover?
"10" quarts!!!
To fill the extra "quart" recommended, it takes around 7 quarts with the fast coolers.
Those must be some coolers! I put a little under 6 QTS in my 5600 the last time I changed fluid... do they really add 4 QTS to the capacity?
Heck, I was putting in 5 qts with just the stock PTO covers on there. Blumenthals built it, I'll put in what they say. When I service it in the spring... if time permits, I'll try to see just how much "extra" they hold. IIRC, they said they like to overfill 2 qts above what would be considered "stock". So, 5 qts, plus the 2 extra, plus 1. 5 for each cooler sounds about right. Been in there for a few months, no leaks.![]()
