What Turbo
TST problems (I think)
Steel suppliers?
Looking to do a Turbo upgrade have been looking at Industrial Injection Silver 62 or ATS Aurora 3000. Truck is driven 50% pulling 15,000# Will these work with just the juice or will I need additional fuel upgrades. Will they fit with factory jacobs brake? I was told I might have to beat the firewall in 3" for brake clearance. That is not an option.
unless you're doing studs boost over 45psi is dangerous to your headgasket. HTT and others offer turbo upgrades which use the factory housing(can keep exhaust brake) and keep EGTs in check while towing w/juice. I run the HTBG 57/12 w/ SMARTY , injectors ,NANO and 4" exhaust, dont even have to look at EGT towing ! runs 36psi easy or up to 48psi(wasted)with TST on.
whoever told you about the firewall needing to be beat in 3" is way off LOL. The brake will bolt right to the new charger as long as you order it with the 3rd gen style outlet. As for boost, the 3rd gens will take considerably more than the 2ng gens on a stock gasket. 55-60 is not a problem with the MLS gasket
