what twin set up?
Upgraded the BD twins to… MPI Super B/GT4202
How is everybody's 48re?
hi all !im thinking on a set of twins, im gonna be towing a fiver(31'-to-38')on some weekends or sort trips. any suggestions on a some sets or even goto a truck depot/junk yard and pipe my own?
I'm not seeing a whole ton of power in your sig. If you're handy w/ cutting and welding, I would:
cut back the divider on your stock turbo's exhaust housing and port out the wastegate hole.
then hang a K31 under it. You can get them brand new for under $800. Very nice turbos and internally wastegated, so you'll be able to ACTUALLY control boost by controlling turbine speed instead of just using plumbing valves to vent it to the atmosphere.
I'd drop a set of head studs in it for good measure
at your fueling levels, you'll never have to look at the pyro again! :D
call enterprise engine they have a great new towing kit talk to drew you might want to add a set of injector tips to ddp 50hp you will love the results there # is 740-246-6329
forest i guess i should explain that ill be buying other power mods in future ;smarty water or nit injectors (sm like 80 to 110 hp maybe) and a turbo. obviously i should have mentioned it before. i just wanted to do some home work on what to save for,sorry----la
Call Nathan @ MPI, he can set u up with your stocker over a s400 or whatever u may need!:-laf 208-884-1250
