Template errors
  • Template public:thread_view: [E_USER_WARNING] Method canConvertThreadToRmsItem is not callable on the given object (SV\SearchImprovements\XF\Entity\ThreadCollab) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsReview is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsQuestion is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsFaq is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsEvent is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsLocation is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template public:post_macros: [E_USER_WARNING] Method canConvertPostToRmsCheckIn is not callable on the given object (SV\WarningImprovements\XF\Entity\Post) (src/XF/Template/Templater.php:1277)
  • Template :: [E_USER_WARNING] Method canViewRmsItems is not callable on the given object (SV\AdvancedBbCodesPack\XF\Entity\User) (src/XF/Template/Templater.php:1277)
2nd Gen Non-Engine/Transmission What type of brake bleeder
2nd Gen Non-Engine/Transmission boots-up or down?
1tuffram
I'm looking for something better than my Mityvac hand held vac pump for flushing and bleeding the brake system on a 4 wheel ABS system. Don't know if it's better to go with a pressurized or vaccum type system. I have been looking at a vaccum type bleeder from both Vacula and Mityvac which uses compressed shop air to help suck the brake fluid out down at the bleeder screws. I have also seen an affordable pressurized bleeder (which looks like a modified garden/weed sprayer) from Motive products. :confused:
I've used the Vacula one. I like it. Whichever one you use, make sure you are careful about sucking air back up the line when you shut the vacuum off. Two way to deal with it.
1: Do a quick pressure bleed after the fluid is exchanged.
2: When shutting off the vacuum, don't do it quicky. Slowly decrease the vacuum until it is stopped. Then wait 30 seconds or so before closing the bleeder.
Joe
how bout the speed bleeders they sell, ya know the replacement ones you screw in place of the factory ones. you can move alot of fluid and its a one man operation...
I've been thinking about a better/faster way to bleed the brakes also. I looked into the pressure bleeder, but don't know anyone who's used one before. Any input fro someone with experience with pressure bleeders would be appreciated.
Speed Bleeders work reasonably well, as long as your system is pretty full of fluid. If you've got big air pockets, or new lines, new cylinders, etc. , it's pretty common for the check valves to not open up.
