What I think you are seeing in your pre-filter is --- aluminum shavings from the fuel tank module. If you've ever seen one out of the tank ... you will notice that the module is somewhat spring loaded and moves inside your fuel tank. I wouldn't get too worried about the shavings ... I've seen them in mine. I had to replaced the fuel tank module a couple of years ago because the fittings broke when I was changing my third sending unit ...
'95 2500 Stretch 4X4, Auto, 3. 54, 265/75/16, white. TST #5 250/635 plate, 215/230 injectors, Pschotty Air, Cummins chrome, BD Valve Body, Pro-torque LS convertor, BD pressure-loc, mystery switch, JRE 4" turbo to tailpipe w/ monster tip, BD exhaust brake, ISSPRO boost and pyro, Grover air horns, Pioneer CD system, Galaxy 99 CB w/ 400 linear, nerf bars, Rancho 9000's, 8K tag-a-long RV ... Life is Good!
