SSolderitch
I have a bad thermostat... wating to spring fro fix. No cab heat. So I installed grill inserts to block off the air flow. Now I have to much heat, can run with window opened. My gauge shows about 180 to almost 190 degrees but never over, I can run all day long. Is the about were I should be? If it would have gone above 190 degrees I would have pulled over and removed 1 or 2 panels. Empty truck not towing or plowing, eastern PA winter, temps avg 30 degrees outside.
